How can I delete parts?
To delete batch parts, select the option Definitions| General | File Import:
  1.  The import screen is displayed;
  2. Select the option Delete Parts;
  3. Download the template file to be loaded, on the upper part of the screen and fill in the file;
  4. Later, you must fill in the file according to the rules.
    1. The field PartKey must be defined.
    2. When the import is finished, the import date will be presented, and it might (or not) contain messages with import details. If an import occurs without errors/warnings, no information on the import details will be presented. If there are errors/warnings, you can see the errors by clicking on the number of messages.
When filling in the file, you must consider the following field:
  1. The file must always be of the CSV type and the separator character must be ; (semicolon).
You must not remove or add columns to the downloaded template.
    • How to batch delete spare parts?
      To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
    • How to import spare parts?
      The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
    • How to import parts?
      The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
    • How do I import parts entry?
      The parts entries in stock can be fed from individual records or through batch records by importing .csv files. To load batch parts entries, select the option Definitions | General | File Import or using the parts entries list ( Parts and Inventory | ...
    • How to import maintenance plans?
      The maintenance plans can be introduced using individual records or by using batch records, by importing .csv files. To batch load maintenance plans select the option "Definitions| General | File Import": The import screen is presented; Select the ...
