How to delete maintenance plans?
To delete maintenance plans in batches, select the option Definitions| General | File Import:
- The import screen is presented;
- Select the option Delete Maintenance Plans;
- Download the template file to be loaded, on the upper part of the screen and fill in the file;
- Then, you must fill in the file according to the rules
- The field MaintenancePlanKey be defined.
- When the import is finished, the import date will be presented that might (or not) contain messages with import details. If an import occurs with no errors/warnings no information on the import details will be presented. If the import records errors/warnings, you can see the errors by clicking on the number of messages.
When filling in the file, you must consider the following points:
- The file must always be of the CSV type and the separator character must be ; (semicolon);
How to import maintenance plans?
The maintenance plans can be introduced using individual records or by using batch records, by importing .csv files. To batch load maintenance plans select the option "Definitions| General | File Import": The import screen is presented; Select the ...
How do I delete preventive maintenances?
To delete preventive maintenances, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Preventive Maintenances; Download the template file to be loaded, on the upper part of the screen and ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How can I delete parts?
To delete batch parts, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Parts; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, you ...
How to delete batch locations?
To delete batch Locations, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Locations; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, ...
