How to delete batch locations?
To
delete batch Locations, select the option Definitions| General | File
Import:
- The
import screen is displayed;
- Select
the option Delete Locations;
- Download
the template file to be loaded, on the upper part of the screen and fill
in the file;
- Later,
you must fill in the file according to the rules:
- The fields LocationKey, and Company must be defined.
- If
the column LocationKey is not filled in, the row will be ignored.
- On
the column ParentLocation can also place the Parent Location.
- Only
the locations that have not been referenced on the product will be
deleted. For example, the locations associated in work orders cannot be
deleted.
- When
the import is finished, the import date will be presented, and it might
(or not) contain messages with import details. If an import occurs
without errors/warnings, no information on the import details will be
presented. If there are errors/warnings on the import, you can see the
errors by clicking on the number of messages.
- A
specific template is made available to batch delete locations. However,
it is possible to use the same template used to import locations.
The file must always be of the CSV type and the separator
character must be ; (semicolon).
You must only specify the field 'Company' if you have more than
one company in your subscription.
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
How to import maintenance plans?
The maintenance plans can be introduced using individual records or by using batch records, by importing .csv files. To batch load maintenance plans select the option "Definitions| General | File Import": The import screen is presented; Select the ...
How to load batch locations?
The locations can be inserted from individual records or through batch records by importing .csv files. To load batch locations, select the option Settings| General | File Import: The import screen is displayed; Download the template file to be ...
How do I delete batch equipments or tools?
To delete batch assets, select the option Settings | General | File Importation: The import screen is presented; Select the option Delete Equipments or Tools; Download the model file on the upper side of the screen and fill in the file; You must fill ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
