How do I delete batch equipments or tools?
To delete batch assets, select the option Settings | General | File Importation:
- The import screen is presented;
- Select the option Delete Equipments or Tools;
- Download the model file on the upper side of the screen and fill in the file;
- You must fill in the file according to the rules:
- The fields Key and Company must be defined.
- If the column Key is not filled in, the row will be ignored.
- On the column ParentAsset you must insert the Parent Equipment if it is an equipment or a Parent Tool if it is a tool.
- Only the equipments and tools that were not referenced on the product will be deleted. For example, equipments associated to work orders cannot be deleted.
- When the import is finished, the import date will be presented that might (or not) contain messages with import details; if an import occurs with no errors/warnings no information on the import details will be presented; if the import records errors/warnings, you can see the errors by clicking on the number of messages.
- A specific template is provided to delete batch equipments and tools. However, you can use the same template used to import equipments or tools.
The file must always be of the CSV type and the separator character must be “;” (semicolon);
You should only specify the 'Company' field, if you have more than one company in your subscription.
How to load equipments and tools?
The assets can be inserted from individual records or through batch records by importing .csv files. To load batch assets, select the option Settings | General | File Import: The import screen is displayed; Select the option Import Equipment and ...
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
How to delete batch locations?
To delete batch Locations, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Locations; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How do I import tasks?
The tasks can be inserted from individual records or through batch records by importing .csv files. To load batch assets, select the option Definitions| General | File Import: The import screen is displayed; Select the option Import Tasks; Download ...
