How to create work orders from a preventive maintenance event?
From a preventive maintenance event, you can create a work order automatically or on user request.
     i.Automatically
  1. for the Work Order to be automatically generated on the preventive maintenance file, the state in which the work order is created must be defined, on the field "WO State". The automatic rescheduling service must be active.
  2. On the day of the event, when the service is executed, the work order associated with that event will be created.
ii. On User Request
    1. to create the Work Order manually, the user must access the preventive maintenance events list "Work | Preventive Maintenance Events".
    2. Select the event and, on the link "Operations", select "Create Work Order".
To create the work order, you must consider the following rules:
  1. It is only possible to create the work order for events that are active;
  2. It is only possible to create the work order for events with no work order;
  3. It is only possible to create the work order if the previous event has an associated work order;
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • How to batch create work orders using preventive maintenance events?
      Managing preventive maintenance events allows you to create Work Orders for each preventive maintenance event. To do so, follow these steps: Go to Work | Preventive Maintenance | Prev. Events Management; Filter the data by Preventive Maintenance, ...
    • How do I change the preventive event date on the event form?
      On the preventive maintenance event form, you can postpone or delay the event date according to the following rules: The new event date must not be earlier than the previous event or later than the next one, in order to maintain the order of the ...
    • How to join plans on the preventive maintenance?
      When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
    • How does preventive maintenance rescheduling work?
      The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
