How do I create misc costs types?
The misc costs types allow to classify the work order misc costs. To create a new Misc Costs Type select the option Definitions | Work | Misc Costs Types:
- The list of misc costs types is presented;
- Press the button "create"
The misc costs types have the following rules:
- The minimum value cannot be negative or higher than the maximum value.
- The default value cannot be inferior to the minimum value nor higher than the maximum value.
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How to create a work order type?
Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
How can I see the Costs dashboard?
The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
How do I consult the Miscellaneous Costs list?
The maintenance manager can check all the miscellaneous cost records associated with a work order. You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the ...
How to create a work order?
