How do I create document types?
The document types allow to set the documents that will be managed in the inventory area. To create a new Type of Document select the option Definitions | General | Types of Document:
- The list of document types is presented;
- Press the button "create"
When creating the document types, you must consider the following points:
- A default document type must exist, and there can only be one.
- The series list cannot be empty.
- A default series must exist, and there can only be one.
- The series list cannot contain repeated series.
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How to create specification types?
The characteristic types allow to configure the characteristics. To create a characteristics type, select the option Settings | General | Characteristics Types: The list of characteristic types is displayed; Press the "Create" button. When creating ...
How to create calendar event types?
The calendar event types allow to configure the calendars. To create calendar event types, search: Calendar Event Types: i.The list of calendar event types will be displayed; ii.Press the "Create" button. When creating calendar event types you must ...
How to create email templates?
Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
How to create task verification types?
How do I create parts?
Items can be used in the maintenance plans for forecasting needs and/or in the material consumption report after being created. To create an item, select the option Parts and Inventory | Parts: The parts list is presented Press the button "create" ...
