How to batch create work orders using preventive maintenance events?
Managing preventive maintenance events allows you to create Work Orders for each preventive maintenance event. To do so, follow these steps:
  1. Go to Work | Preventive Maintenance | Prev. Events Management;
  2. Filter the data by Preventive Maintenance, Workshop, Start and End Date, Location, Equipment, Tool and/or Route (optional);
    Note: the start and end dates correspond to the expected date of the event;
  3. Click on Apply;
  4. Preventive maintenance events are displayed;
  5. Select the events for which you want to create the Work Order;
  6. Click on Create WO or Create WO and Print. If you chose the second option, you can select the double-sided printing type.
Work orders are only printed when processing is complete. When this happens, the Manager is notified and can download the printing in the Notifications area.
If you want to verify the processing's current status, click on View Status at any time or on the link available in the notification.
    • How to create work orders from a preventive maintenance event?
      From a preventive maintenance event, you can create a work order automatically or on user request.      i.Automatically for the Work Order to be automatically generated on the preventive maintenance file, the state in which the work order is created ...
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • How to join plans on the preventive maintenance?
      When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
    • How does preventive maintenance rescheduling work?
      The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
    • Calculating Preventive Maintenance events with counters and Opening or Closure scheduling criteria
      The cumulative reading value of a preventive maintenance event becomes the same as the last counter reading when: the Work Order has an associated preventive event; the event is the last one with an associated Work Order (most recent); the preventive ...
