How do I create parts?
Items can be used in the maintenance plans for forecasting needs and/or in the material consumption report after being created. To create an item, select the option Parts and Inventory | Parts:
  1. The parts list is presented
  2. Press the button "create"
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
    • How to record a stock parts entry?
      The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
    • How to report/delete a stock parts issue?
      The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
    • How to create email templates?
      Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
    • How to use spare parts?
      In an equipment, tool or location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Location" / "Equipment" / "Tools" Edit or create "Location" / "Equipment" / "Tools" On the Spare Parts ...
    • How do I consult the parts/warehouses list?
      Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
