How can I create monitorings?
The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, select the option Assets | Meters and Monitorings | Meters:
  1. on the list
  2. press the button "create".
When creating the monitoring, you must associate it to one of the following elements:
  1. Location function - when creating a monitoring to a location function, this means that when recording meter values, the user must select a location with this location function associated.
  2. Family - when creating a monitoring to a family, this means that when recording monitoring values, the user must select an equipment or tool with this family associated.
  3. Brand - when creating a monitoring to a brand, this means that when recording monitoring values, the user must select an equipment or tool with this brand associated.
  4. Brand and Model - when creating a monitoring to a brand or model, this means that when recording monitoring values, the user must select an equipment or tool with this brand or model associated.
  5. Localization - when creating a monitoring to a location, this means that when recording monitoring values, the user can only do it for the monitoring location.
  6. Equipment - when creating a monitoring to an equipment, this means that when recording monitoring values, the user can only do it for the monitoring equipment.
  7. Tool - when creating a monitoring to a tool, this means that when recording monitoring values, the user can only do it for the monitoring tool.
If the fields Action and Warning are filled in, they must obey the following order (Superior action > Superior warning > Inferior Warning > Inferior Action):
  1. The field superior action must be higher than the superior Warning
  2. The field superior warning must be higher than the field inferior warning
  3. The field inferior warning must be higher than the field inferior action
The field Action Trigger Events defines the consecutive number of values necessary to trigger an action.
The field Window indicates the number of monitoring records that will be used to calculate the average.
Fill in the monitoring data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
    • How do I create assets?
      The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
    • How do I use the Assets Explorer?
      The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
    • How to associate assets to workshops?
      For bigger clients with several workshops, there is frequently the need to specify assets (equipment, tools and locations) that each workshops have access to. Using this feature, the user can specify the assets associated to each workshop. When ...
    • How do I insert monitoring values?
      The Valuekeep monitorings can be fed information from individual records or through batch records by importing .csv files. To insert a new monitoring reading select the option Assets | Meters and Monitorings | Monitorings: A monitoring list is ...
    • How to create email templates?
      Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
