The meters are system entities which allow for monitoring parameters of the assets operation in order to trigger Preventive Maintenance actions. The meters can operate as autonomous units or have other meters associated with it.
To create a new meter, select the option Assets | Meters and Monitorings | Meters, on the list, press the button "create".
Fill in the meter data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
When creating the meter, you must associate it to one of the following elements:
- Location function - when creating a meter to a location function, this means that when recording meter values, the user must select a location with this location function associated.
- Family - when creating a meter to a family, this means that when recording meter values, the user must select an equipment or tool with this family associated.
- Brand - when creating a meter to a brand, this means that when recording meter values, the user must select an equipment or tool with this brand associated.
- Brand and Model - when creating a meter to a brand or model, this means that when recording meter values, the user must select an equipment or tool with this brand or model associated.
- Localization - when creating a meter to a location, this means that when recording meter values, the user can only do it for the meter location.
- Equipment - when creating a meter to an equipment, this means that when recording meter values, the user can only do it for the meter equipment.
- Tool - when creating a meter to a tool, this means that when recording meter values, the user can only do it for the meter tool.
If the meter has a parent meter associated, you must consider the value of the following fields:
- Location function - you can only select a parent meter with the location function field filled in and the same as the meter you are creating.
- Family - you can only select a parent meter with the family field filled in and the same as the meter you are creating
- Asset (location, equipment or tool) - you can only select a parent meter with the asset field filled in and the same as the meter you are creating.
On the Characteristics tab, you can assign one or
more characteristics to meters.
