The creation of locations is a critical
step for the configuration of the system. Besides setting which locations are
subject to maintenance, locations will also contain the assets.
To create a location, select the option Assets | Locations:
Presents the location list;
Press the "Create" button;
When creating a location, you must
consider:
i.
When
creating a location, it will be automatically associated to the workshop and
access level by default.
ii.
It is
automatically created as "Available" and the entry date to the
current service.
iii.
See Quick
Guide: press user icon and select the option Quick Guide.
Location Characteristics
In the Characteristics tab, you can assign one or more
characteristics to the location function. These can be of the following
types:
Number;
Text;
Date/Time;
Boolean;
Enum.
When saving the location function record, the following
validations regarding the characteristics are made:
No repeated characteristics can exist
Number type characteristics: checks if the text inserted
on the Value field is a number. The number of decimal places associated
to that characteristics unit is also checked, as well as if the tab
matches the user language;
Date/time type characteristics: checks if the text
inserted on the Value field is a date and/or a time.
Boolean type characteristics: checks if the text inserted on
the Value field is 0 for False and 1 for True;
Enum type characteristics: checks if the Enum value
matches the values for the selected characteristic.
There are a few rules to edit Locations,
among them:
- It is only possible to edit the
service date if there are no down times reports.
When creating a new location, this is
placed as "Available" and the "Service Date" as the current
day.
If the asset was not created as Available,
after the Service Date, the asset is placed automatically as available.
To automatically make it available, you
must select the option "Definitions | Work | Background
Services" and activate the Downtime.
On the Universe line, you can have a subscription with several companies and define a set of information for each company, including users and time zone. Add more companies to a subscription Access Settings | General | Companies; Press the Create ...
This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
In an location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Locations"; Edit or create a "Location"; On the Spare Parts tab, you can add a Part and the corresponding quantity, you ...
For bigger clients with several workshops, there is frequently the need to specify assets (equipment, tools and locations) that each workshops have access to. Using this feature, the user can specify the assets associated to each workshop. When ...
