How do I create a location function?
To create a new location function, select the option Definitions | Assets |Location Functions;
- The location function list is presented,
- Press the button "create"
Location function characteristics
In the Characteristics tab, you can assign
one or more characteristics to the location function. These can be of the
following types:
- Number;
- Text;
- Date/Time;
- Boolean;
- Enum.
When saving the location function record,
the following validations regarding the characteristics are made:- No
repeated characteristics can exist
- Number
type characteristics: checks if the text inserted on the Value
field is a number. The number of decimal places associated to that
characteristics unit is also checked, as well as if the tab matches the
user language;
- Date/time
field is a date and/or a time.
- Boolean
type characteristics: checks if the text inserted on the Value field is 0
for False and 1 for True;
- Enum
type characteristics: checks if the Enum value matches the values
for the selected characteristic.
The location function that we've created cannot be invoked as a Location Parent Function.
How do I use the Assets Explorer?
The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
How to create email templates?
Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How can I create monitorings?
The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, ...
How to add a location?
The creation of locations is a critical step for the configuration of the system. Besides setting which locations are subject to maintenance, locations will also contain the assets. To create a location, select the option Assets | Locations: Presents ...
