How do I create failure symptoms?
To create a new Failure Cause, select the option Definitions | Work | Failure Symptoms, Causes and Actions;
- A failure symptoms, causes and actions list is presented,
- Press the button "create"
Failure symptoms
- In the Failure symptoms tabs, we must associate failure symptoms
- It is not possible to specify the same failure causes
How can I report a failure?
Reporting failures allows for entering into the system failures related to assets (equipments and tools), for a subsequent monitoring and handling by maintenance. It is only possible to create a failure associated with a work order. To create a ...
How do I create a failure action?
To create a new Failure Action, select the option Definitions | Work | Failure Actions; The failure actions list is presented, Press the button "create" Fill in the data. The information to be filled in is organized in tabs. You can see the required ...
How to create a work order type?
Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
How can I crate failure causes?
To create a new Failure Cause, select the option Definitions | Work | Failure Causes; The failure causes list is presented, Press the button "create" Failure Actions In the Failure Actions tabs, we must associate failure actions It is not possible ...
How to create a related work order?
Frequently, a maintenance technician is performing a work order and detects another problem, so he needs to solve it and log the work done. To log the work done, there are 3 options: Creating a new work order Adding additional tasks to the work order ...
