How can I crate failure causes?
To create a new Failure Cause, select the option Definitions | Work | Failure Causes;
- The failure causes list is presented,
- Press the button "create"
Failure Actions
- In the Failure Actions tabs, we must associate failure actions
- It is not possible to specify the same failure actions
How do I create failure symptoms?
To create a new Failure Cause, select the option Definitions | Work | Failure Symptoms, Causes and Actions; A failure symptoms, causes and actions list is presented, Press the button "create" Failure symptoms In the Failure symptoms tabs, we must ...
How can I report a failure?
Reporting failures allows for entering into the system failures related to assets (equipments and tools), for a subsequent monitoring and handling by maintenance. It is only possible to create a failure associated with a work order. To create a ...
How do I create a failure action?
To create a new Failure Action, select the option Definitions | Work | Failure Actions; The failure actions list is presented, Press the button "create" Fill in the data. The information to be filled in is organized in tabs. You can see the required ...
How to see the list of failures?
From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order. To see the menu list select the option "Work | Explore | Failures". The failure list follows these ...
How to create a related work order?
Frequently, a maintenance technician is performing a work order and detects another problem, so he needs to solve it and log the work done. To log the work done, there are 3 options: Creating a new work order Adding additional tasks to the work order ...
