How do I create an employee?
To create a new Employee, select the option Definitions | Workshops and Employees | Employees:
  1. The employee list is presented,,
  2. Press the button "create"
When creating or editing an employee, you must consider the following points:
  1. When creating an employee automatically, he will be associated to the workshop and to the access level by default
  2. An employee can have a login in Valuekeep, if it does have a login to enter Valuekeep in the field "Username" you must insert the email used to log into Valuekeep, so that the system knows that the employee X is mapped to the user y.
  3. Example:
    1. The login to enter Valuekeep is: JoaoXX@Valuekeep.com. This means that the Valuekeep user is:JoaoXX@Valuekeep.com
    2. When creating the employee on the field "Username" you must insert JoaoXX@Valuekeep.com
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
    • How can I create a workshop?
      The workshops represent a way of organizing work groups by area, in order to be able to create access restrictions in the operations for allocation of costs to the work orders. To create a new workshop, select the option Workshop & Employees | ...
    • How to create a work order type?
      Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
    • How to create email templates?
      Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
    • How to create contracts?
      To create a new contract, select the option "Contracts | Contracts": The contract list is presented: Press the "Create" button. When editing the contract, you must consider: The state change must be performed on the detail view interface. If the ...
    • How to create specification types?
      The characteristic types allow to configure the characteristics. To create a characteristics type, select the option Settings | General | Characteristics Types: The list of characteristic types is displayed; Press the "Create" button. When creating ...
