How can I see the Costs dashboard?
The dashboard Costs shows metrics and indicators related to the recording of costs in work orders.
To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with all the dashboards provided by Cegid Valuekeep. On this page, click on Costs.
Information available
Through this dashboard, you can see a range of data related to the recording of costs, divided into 8 tabs:
1. Summary
Here, the KPIs are shown with the sum:
  1. of all the costs of the 3 types (labour, consumables and miscellaneous costs);
  2. of all labour costs;
  3. of all consumable costs;
  4. of all miscellaneous costs.
The graphs show:
  1. monthly maintenance costs by category;
  2. costs by type of work order;
  3. 5 main total family costs;
  4. 5 total costs by location function.
2. Workshops
In this tab, you have access to:
  1. graph with information on the five highest costs per workshop;
  2. table with the costs by category and workshop.
3. Families
Here you can see:
  1. in the table, the costs per family;
  2. in the bar chart, the top 5 costs by family and category;
  3. in the pie chart, the top 10 costs per family.
4. Device
Here you can see:
  1. in the table, the device costs;
  2. in the table, the top 5 costs of parent devices;
  3. in the pie chart, the top 10 costs per parent device.
5. Tools
Here you can see:
  1. in the table, the costs of the tools;
  2. in the table, the top 5 costs of the parent tool;
  3. in the pie chart, the top 10 costs per parent tool.
6. Location Function
Here you can see:
    1. in the table, the costs of the location function;
    2. in the bar chart, the top 5 costs by location and category;
    3. in the pie chart, the top 10 costs by location.
    7. Location
    Here you can see:
        1. in the table, the costs of the locations;
        2. in the table, the costs per parent location;
        3. in the pie chart, the costs per parent location.
        8. YoY (Year over Year) analysis
        Through the graph, you can see:
        1. the monthly costs and comparison with previous years;
        2. the costs per year;
        3. the percentage of costs per year.
        Filters
        In any tab, you can change the filters using the option Edit filters. You should bear in mind that
        1. The filter Company only shows the companies to which you have access;
        2. In the filter selector you can only select data with dashboard records;
        3. The data on the dashboards is updated at the end of the day;
        4. All figures are shown in the reporting currency.
          • How do I see the Faults dashboard?
            The dashboard Faults shows metrics and indicators relating to the fault record of devices and tools. To access this dashboard, click on the icon Applications in the top left corner of the header, and then in the option Analytics. A tab will open with ...
          • How can I see the Labor dashboard?
            This dashboard shows metrics and indicators related to labor. To access this dashboard, click on the icon Applications in the top left-hand corner of the header, then Analytics. It will open a tab with all the dashboards provided by Cegid Valuekeep. ...
          • How do I see the Downtime dashboard?
            The dashboard Downtime shows metrics and indicators related to asset downtimes. To access this dashboard, click on the Applications in the top left-hand corner of the header, and then the Analytics option. A tab will open with all the dashboards ...
          • How can I see the Requests dashboard?
            Through this dashboard, you have access to metrics and indicators related to Requests. To access this dashboard, click on the icon Applications in the top left corner of the header and then in the option Analytics. A tab will open with all the ...
          • How do I use the Analytics feature (dashboards)?
            Cegid Valuekeep is focused on developing features that help decision-making based on data that are exact and precise. For this purpose, there is an add-on tool which enables companies to monitor performance, reduce downtime and reduce costs. Once you ...
