The maintenance manager can check all the miscellaneous cost records associated with a work order.
You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the header.
The list of miscellaneous costs has the following criteria:
- By default, only the miscellaneous costs for the current quarter are shown.
- The list is sorted in descending order of the expected date of the work order.
- From the list, you can access the work order view screen.
- You can search within the list. By default, the Work Order, Description filter is selected, but you can change it.
This functionality is available for the Administrator and Work Manager profiles.
