How to report monitoring values associated with the work order?
Every time the Work Order state is configured to allow recording work, it will be possible to associate monitoring readings to the work order, if the work order asset has associated monitoring. To record monitoring readings for the Work Order select the optionWork | Work Orders Work | Work Orders
- The work order list is presented.
- Select the Work Order of which you wish to record monitoring values
- On the Operations link, select the option "Meter readings"
- The list of meters associated to the Work Order asset is presented
- When loading the "Load Childs" option, all of the meters of the Work Order child assets with no Parent Meter will be loaded.
The values cannot be edited.
How to report meter values associated with the work order?
Every time the Work Order state is configured to allow to record work, it will be possible to associate meter reading to the work order, if the work order asset has associated meters. To record meter readings for the Work Order select the option Work ...
How to report the task verification associated with the work order?
When a work order is in a state that allows to record costs, it is possible to perform the task verification. To check the tasks, you must access the work order file "Work | Work Orders", select the work order that you wish to check the task of. On ...
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
