How to get API credentials for integrations?
To obtain API credentials for integrations, the following steps must be followed:
- In the left side menu, go to Settings | General | Companies;
- Select the company you want to obtain credentials for;
- Select the company Settings tab.
- If the company does not have the Settings tab, edit the company data to add this tab and save the changes;
- In the company Settings tab, open the Custom Settings expander;
- Click on the Generate API Credentials button;
- The new credentials will be sent by email. It is important to save this email for future reference in integrations.
- Also check the Spam or Other folders in case you can't find the message in your inbox.
- Look for an email with the title API CREDENTIALS sent from notifications@valuekeep.com.
When generating new API credentials, the previous ones will no longer work. Make sure you want to generate new credentials before continuing.
The Generate API Credentials button is only available for Universe solutions and the Subscriber of the subscription.
How to obtain a datasource from a simple report with the verification work done in the work order?
This method allows you to obtain a datasource from a simple report with the verification work carried out on a work order, including tasks, verifications and attached images. The method to use is as follows: GET ...
How do I use the Assets Explorer?
The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
How to create an equipment reception document?
To create an equipment reception document, you need to follow these steps: In the Assets menu, select the Equipment Receptions option; A list of existing Equipment Reception documents will be displayed; Click on the Create button; The following ...
