How to print a Work Order task verification report?
To print a work order task verification report, you need to follow these steps:
  1. Go to Work | Work Orders;
  2. Select a work order record;
  3. In the bottom left-hand corner, click on the three dots to access the Print Verification Report option.
This report contains information about the verification carried out on the work order, including tasks, verifications and attached images.
Information included in the report
  1. Header:
    1. Company logo (if defined);
    2. Work Order key and description;
    3. Asset key and description;
    4. Customer key and description;
    5. Description of the Work Order type;
    6. Workshop description;
    7. SLA start date;
    8. Description of the Work Order status;
    9. Name of the responsible for the Work Order;
    10. SLA end date;
    11. Remarks on the Work Order.
  2. Detail Verifications:
    1. Asset key and description;
    2. Maintenance plan key and description;
    3. Plan tasks key and description;
    4. Work Order tasks key and description;
    5. Verification value and remarks.
  3. Detail Attachments:
    1. File name and address of the image of the Work Order attachment.
    • How to report the task verification associated with the work order?
      When a work order is in a state that allows to record costs, it is possible to perform the task verification. To check the tasks, you must access the work order file  "Work | Work Orders", select the work order that you wish to check the task of. On ...
    • How to create a template report for work orders?
      To create a new template report for work orders, select the option Settings | Printing | Reports. Edit the "Work Order" template and, on the options, click "Copy to New". To make this the default report, select the tab "Entity Groups" and click the ...
    • How to report consumptions associated with the work order?
      When a work order is in a state that allows to record costs, it is possible to record  material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
    • How to report labor associated with the work order?
    • How to report misc costs associated with the work order?
      When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs  you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
