How to create a related work order?
Frequently, a maintenance technician is performing a work order and detects another problem, so he needs to solve it and log the work done. To log the work done, there are 3 options:
  1. Creating a new work order
  2. Adding additional tasks to the work order being executed
  3. Creating a new work order related to the one being worked on
To create a work order related to the work order being worked on, you must follow these steps:
  1. Access the list of work orders;
  2. Edit a work order;
  3. On the option (...) select "Create Related Work Order".
  4. The work order creation window is opened, copying all the original work order data and filling in the field "Source Work Order" with the original work order. Only attachments, follow-ups, additional tasks and cost details are not copied. The technician can also perform this operation.
    • How to create a work order?
    • How to create a work order type?
      Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
    • How to consume spare parts on the work order?
      On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
    • How do I create the work order type?
      Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
    • How to create a template report for work orders?
      To create a new template report for work orders, select the option Settings | Printing | Reports. Edit the "Work Order" template and, on the options, click "Copy to New". To make this the default report, select the tab "Entity Groups" and click the ...
