How to assign messages to a work order?
The
maintenance manager and the technician can insert additional tracking messages
on the work order context.
To add a
new message, please follow these steps:
- Edit the
work order;
- Open the
"Follow-up" tab;
- Add a new
message and insert the content;
- Define the
message visibility on the field "Visible to".
- If you
select the option "All" (default), the messages will be visible to
everyone related to this work order, as maintenance managers, employees
assigned to the work order and who created the request. If you select this
option, the work order is copied to the requests.
- If you
select the option "Maintenance Team", only the user and the
maintenance managers or technicians assigned will see the messages. In this
case, the message is only created on the work order.
- Save the
changes to the work order;
The
messages are visible to all users configured on the option "Visible
to". After saving the changes, the message cannot be deleted nor changed.
How do I consult the follow-up messages associated with a work order?
Work orders (WO) can contain follow-up messages. This information is very useful for the administrator to track each WO. To consult the list, simply go to Work | Explore Work | Follow-up Messages or search for Follow-up Messages in the search ...
How to assign technicians to the work order?
When a work order is in a state that allows it, you can assign technicians. To assign technicians on the WO, you must access the work order file you wish to assign in "Work | Work Orders" and select the desired WO. On the work order file, on the link ...
How do I manage batch work orders?
Work Order (WO) management was designed to increase the maintenance manager productivity. Thus, with this feature, the manager is now able to: change the state of several WOs simultaneously; print several WOs simultaneously; To manage WOs in batch, ...
How to configure the work order workflow?
The state flow for work orders can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Work | Workflow The state list is presented; To create new states, ...
How do I create the work order type?
Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
