How do I check the Batch Processing Status?
The list Batch Processing Status has been designed to display more details on batch operations and so give a precise and accurate analysis of all batch processing.
You can access this option by searching for Batch Processing Status in the search bar in the header.
In this list, you can filter by all fields and it is sorted by creation date (Created in). It has the following structure:
- Queue: Sequential key for batch processing;
- Entity: Record entity
- Entity Key: Record key;
- Description: Record Description (in the case of Events it is the Preventive Maintenance Description);
- Task Status:
- New: when the record is created and has not yet been executed;
- Closure: when the record has been successfully completed;
- With errors: when a record error occurred;
- Error message: error message in English (EN);
- Status code: "status code" of the http request:
- 200: successfully executed;
- 400: Error found;
- 500: Problem not found but not successfully executed;
- Created by: Employee who did the batch processing;
- Created in: Date processing was created.
How to batch create work orders using preventive maintenance events?
Managing preventive maintenance events allows you to create Work Orders for each preventive maintenance event. To do so, follow these steps: Go to Work | Preventive Maintenance | Prev. Events Management; Filter the data by Preventive Maintenance, ...
How do I manage batch work orders?
Work Order (WO) management was designed to increase the maintenance manager productivity. Thus, with this feature, the manager is now able to: change the state of several WOs simultaneously; print several WOs simultaneously; To manage WOs in batch, ...
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
How do I load batch meter readings?
The meter values can be fed information from individual records or through batch records by importing .csv files. To load batch meter reading, select the option Definitions | General | File Importation or using the meter reading list (Assets | Meters ...
How to delete batch locations?
To delete batch Locations, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Locations; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, ...
