Calculating Preventive Maintenance events with counters and Opening or Closure scheduling criteria
The cumulative reading value of a preventive maintenance event becomes the same as the last counter reading when:
  1. the Work Order has an associated preventive event;
  2. the event is the last one with an associated Work Order (most recent);
  3. the preventive event has scheduling criteria Opening or Closure;
  4. a counter is associated with the preventive event plan.
This happens when opening or closing a Work Order for editing.
In other words, when opening/closing the preventive Work Order and if you have associated a preventive event with criteria other than Fixed the application updates the cumulative value of the event with the current counter reading.
In the next recalculation, the next events will be calculated based on the reading from the last event.
When the criterion for scheduling preventive care is Closure, the Work Order for the next event is opened if the Work Order of the previous event is in a status that ends the SLA end date (Work Order Status Flow).
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • Criteria for Preventive Maintenance with meters
      When you create a preventive maintenance with meters and the configured meter in the maintenance plan has meter readings, when you approve the preventive maintenance and generate the events the commutative meter reading in the event starts at the ...
    • How to batch create work orders using preventive maintenance events?
      Managing preventive maintenance events allows you to create Work Orders for each preventive maintenance event. To do so, follow these steps: Go to Work | Preventive Maintenance | Prev. Events Management; Filter the data by Preventive Maintenance, ...
    • How to join plans on the preventive maintenance?
      When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
    • How to set the preventive maintenance plan replacement?
      On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
