On the Universe line, you can have a subscription with several
companies and define a set of information for each company, including users and time zone.
After creating the company, you can switch between companies in the company selector (located above in the features menu). Whenever you want to create records, they are associated with the company selected in the selector.
When more than
one company is added to a subscription, you can specify the user that can
access each company. The access restriction process is divided in two steps:
Step 1: Create Restriction Groups
Access the menu Settings | System | Groups;
Click on Create;
Enter the group's identification data and select the users you want to be in this group;
Click in Save.
Step 2: Adding the restriction
groups to the company:
Access the menu Settings | General | Companies;
Creating or editing the
company;
Click on the + icon and select the Access Restrictions tab;
Select the user group previously created;
Click on Save.
Users have access to notifications if they have access to the company.
When adding
more companies to a subscription, it is possible to specify the settings for
each company.
1. Access the menu Settings | General | Companies;
2. Creating or editing the
company;
3. Add the Settings tab.
The dates
present when sending notifications will be converted to the chosen time zone.
If a time zone is not chosen, the default will be UTC +00:00
You can only
change the organization's currency if there are no records in the tables with
base/reporting currency (only transactional/documents, stock entries/issues and
costs).
The list data
is always filtered by the company selected on the company selector. You cannot
view the data for all the companies simultaneously on the same list.
After selecting
the company on the company selector, the Valuekeep CMMS solution is filtered
for the selected company. The new logs created are associated to the company
On the Universe line, you can have a subscription with several companies. How to add more companies to a subscription? After entering the solution, access: Settings | General | Companies Press the Create button; The new company creation screen is ...
The maintenance manager and the requester can insert additional tracking messages on the request context. To add a new message, please follow these steps: Edit the request; Open the "Follow-up" tab; Add a new message and insert the content; Define ...
After creating a work order, it is possible to add new tasks. To add a Task to a work order, you must access the work order file and open the tab "Additional Work": The list of additional tasks associated to the work order is presented On the list, ...
To add a maintenance plan to a work order, you must access the work order file and open the tab "Maintenance Plans": The list of additional maintenance plans associated to the work order is presented On the list, press the button "+" to add one or ...
To add an attachment to a preventive maintenance, you must follow these steps: Edit the preventive maintenance and click on the option "Attachments" on the options on the lower left corner of the screen; On the "Manage Attachments" pop-up, it is ...
