Access to the App on different devices
The mobile app allows access from any device. That device will be registered in the back office.
Whenever you log in to another device, you will be asked if you want to log out of the previous device. If you do, the first device will continue to work normally until it is time to synchronize.
To synchronize, you will need to log out and log back into the application so that the new device can be registered in the back office.
How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS, before entering the app, you must accept the request you've been sent. Roles supported on the Valuekeep Requester CMMS app: Root - Administrator Requester - Requester RequestsManager - Requests Manager If you ...
How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS, before entering the app, you must accept the request previously sent. Roles supported on the Valuekeep Technician CMMS app: Root - Administrator Technician - Technician WorkManager - Work Manager
Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
Mobile - How to add the user account to the CMMS Valuekeep app?
After downloading the app, it is necessary to add the user account to the app, so that you can login. For that, follow these steps: When first accessing the application, on the initial screen, click the button “Add user”; If there are other accounts, ...
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
